Old 05-01-2016, 11:04 AM
Does anyone know of another way to check hv on this pilot using a regular 0-42 kv hv tester that does work maybe using resistors or a microwave resistor in some configuring way because I do think the hv is low as everything else checks out perfect. They say you cannot use a tester like I have due to high impedance. There must be a way I have nothing else except an analog meter that only goes to 1 kv and even that meter don't go to 1 kv to say that the hv is infact low because my meter should pin if more the 1000 volts.
