OK, I'll see if I can find some.
Well I replaced the original 2000 MFD 30V Power Supply Cap in the radio with a 2200MFD 50V capacitor and its still has a 60Hz Hum coming out of the speaker and still no audio out of the speaker from the tuner. So what should I check next in the circuit that could be causing my issue? I also tried posting this in AudioKarma but for some reason when I went to post it it wouldn't post it would act like it was going to post the thread but then it would wouldn't actually post anything.
I would suspect that one or both of the diodes in the rectifier circuit could be shorted or have very high reverse leakage... you can get a manual here from Phil's old radio site:
http://antiqueradio.org/KLHModelTwentyOne21FMRadio.htm Thanks again to Phil Nelson for his wonderful site, jr |
KLH built some very nice stuff. Our shop saw a lot
of it being 20 miles from Cambridge. Also piles of H.H. Scott that was 5 miles away. Anyhows change ALL the lytics first. I remember a few of the stereo ones going DEAD in one channel & that was it. ( 30 yrs ago ). Another thing that may be it is if it uses ua703 IC's in the IF they were trouble especially on Scotts sets. In any case when its running again you will wonder what all the hoopla about digital is. 73 Zeno
So What's the modern substitute for this part? Is there an NTE Part that subs out for this part?
