The pinout of the 11 pin connector coming from the unit is as follows:
1.) Heater + Ground 2.) Red Cathode 3.) Green Cathode 4.) Red G2 5.) Green G2 6.) Blue G2 7.) Blue Cathode 8.) Red G1 9.) Green G1 10.) Blue G1 11.) Heater A monochrome tube uses the red gun connections, so you connect the corresponding pins of a suitable duodecal CRT socket to an 11 pin plug as follows: CRT Pin CR31 Pin 1 ---> 1 2 ---> 8 10 ---> 4 11 ---> 2 12 ---> 11 This will get you an equivalent for Adapter #1. |
