Old 06-02-2016, 07:12 PM
Telethons tv208
Does anyone know of the name of another set that Was made exactly the same as the picture of my set in early television under teletone tv208. There is another company that made the same only it had different covering and called it another name . I'm trying to find the right schematic for this 208 and mine don't have the ballast but the one in earlytelevision has the ballast and it's different. I have a resistor between the 25z6 and 6x5 tube, 5 and 6 and it got really hot and will need to be replaced and I'm sure whatever it measures it's going to be a lot higher. It measures 1200 ohms it could be right but not sure. It's one of those resistors that look like a mica it has 3 dots but the colors are gone from heat. If I could get a name maybe I'll find it and it may have the right schematic without the ballast which is what I need, don't want to guess this resistor because it's between the rectifiers so it will have to be right.
