Old 06-16-2016, 03:48 PM
Originally Posted by bigaudioal View Post
Easier way to go would be to place a bi-directional TVS diode across the CRT filament. Done.
I used this one:
Diode part no. P6KE8.2CA-TP. Got it here:
https://www.arrow.com/en/products/p6...ponents#page-1
Well I have the diodes coming part number, 1.5ke8.2ca I think they clamp at around 7 volts. The only reason I was looking for the resistor for the filiment is because I have a spare 3 inch crt for my pilot and this tube has the cathode shared with the heater so if I use a 6.3 v transformer I could use that tube or any other. Plus I will be putting the diode in as well.
Old 06-16-2016, 03:53 PM
bigaudioal's Avatar
I got ya. My pilot came with a good 3KP4 that puts out a great pic. I was very fortunate. Diode does a good job of protecting from the start up surge. It is visible noticeable. CRT filament does not get extremely bright and then die down to normal anymore.
-Al
Old 06-17-2016, 11:05 AM
Findm-Keepm's Avatar
Followin' the Rules...
I've used the P6KE7.5CA - keeps it real safe at 7.5V, and a buck gets you 10!
My Silvertone 21" consolette and Emerson luggable are still going strong with them.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
