Old 07-14-2016, 05:27 PM
Telecolor 3007's Avatar
I love old stuff
But how in the world they made the deflection when the gun was underneath?
Sailor Moon
Old 07-15-2016, 12:44 PM
Electron beams can be deflected at 90 degrees or more. It is possible even to make a mirror which can reverse the travel of the beam completely. However, as the beam is deflected more the beam can be de-focused and geometry can suffer. The Sony tvs had considerable keystone correction, and yet the geometry was not very good on these tiny sets.
Old 07-15-2016, 06:11 PM
The screen is the back piece of glass. You look through one sheet of glass, through the vacuum then at the screen on the inside of the back wall of the CRT the screen curves gently out toward the viewer at the top. From the electron gun's perspective it it shooting at a very short wide screen....No crazy deflection angles here.
If you had asked a few months back I'd have given you a working Sony paddle CRT set for the cost of shipping.
Old 07-15-2016, 06:48 PM
That is indeed true for the second generation design, the curved phosphor screen allowed the electron beam to land with only modest vertical deflection required. Magnetic deflection was employed for both axes.
The first generation design employed a flat phosphor screen at 90 degrees to the electron gun. A combination of magnetic and electrostatic deflection was used to achieve proper landing of the beam.
http://www.videokarma.org/attachment...5&d=1256418738
