Old 07-21-2016, 10:07 AM
Sometimes it is possible for the fine tuning to be so far off that the tuner is recieving while set on the next channel and/or tuned to the wrong sideband of a simple modulator.
If you are using channel 3 on the TV, try channel 4 or vice versa. If your modulator is versatile, try both one channel up and one channel down.
Old 07-21-2016, 10:12 AM
baluns, terminations, OTA on that channel, connections, etc...
I had one with an intermittent balun in the tuner that gave me issues once.
Old 07-21-2016, 11:11 AM
Just for the heck of it, try subbing the last IF tube. Ringing/smearing in the luma is a not-uncommon problem caused by the last IF tube, even tho the tube tests 'good' on a tester.
Old 07-21-2016, 12:43 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
I'll switch to channel 4 and sub the 3rd IF 6AN8. Don't see why 8 months would totally mess this thing up.
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
Old 07-21-2016, 02:10 PM
was nothing done to it in those 8 months?
