Old 07-22-2016, 05:42 AM
jstout66 jstout66 is offline
It has to be something simple, since it worked 8 months ago. I'd agree with what Andy and Electronic M said.... Put the shields back. Also, I wouldn't attempt an alignment. They NEVER go out of alignment on their own, unless it's a component failure or someone in the past has been screwing around, and 9 times out of 10, it was somebody that got happy with a set of Radio Shack "diddle sticks". I was also reading some earlier posts. I wouldn't worry too much about the caps. If it was a repair tech that had it in the past, I'd assume it's been re-capped. Maybe I missed it in a prior post, but have you looked yet to verify? I also wouldn't worry too much about the tube conversion job. It looks like it was done long ago, and if it wasn't done right, those problems would have surfaced eons ago. It will be something so simple, you'll probably smack yourself on the head when you figure it out.
