Old 08-08-2016, 04:30 AM
colectorad colectorad is offline
Originally Posted by madlabs View Post
Does the resistor measure open? If not, what is the reading?
Yes. "Burn[ed] open".
Can you follow out the schematic? Maybe we can do some guess work, get within a range. Then maybe try a pot and see if it works OK.
Again, "there's no schematic". The trouble isn't getting it to work, it's getting it to keep working without a domino effect failure from using the wrong resistance.
Probably the best thing is to hit the thrifts for a simular unit. A lot of times, they get donated when the caraffe gets broken.
Unfortunately, it works the exact opposite around here: there's a shelf full of carafes where coffee makers would normally be. In any case, buying another coffee maker would defeat the point of fixing this one.
I'm in need of service manuals for the following:
Magnavox 19C315-CC, Emerson ECT-1300A (TM0110E), Sears 401.50300900
Old 08-08-2016, 09:36 AM
I was thinking about taking apart the good one and finding the resistor value.
The one thrift, I generally go to, has a shelf of carafes, as well.
From year to year, they seem to change the dimensions of the carafes, so many times they don't seem to fit right. Even with the same make.
