Old 08-06-2016, 05:15 PM
john116 john116 is offline
1959 Predicta Tandem - spot suppression?
Hi - just wondering if the Philco Predicta's had spot suppression? Turning mine off results in a bright white dot for a number of seconds.
John
Old 08-10-2016, 04:59 PM
No, they didn't. I don't recall ever seeing a B&W set that did for that matter.
If anyone knows of a model that does, perhaps the circuit could be adapter to a Predicta?
Old 08-10-2016, 07:58 PM
One of the 50's TV mags had an article on spot suppression IIRC.
Old 08-10-2016, 08:57 PM
Use a two pole switch one section for power second section to break the +270 volt connection to the top of the brightness control, that will take the cathode to ground which turns the crt on hard and discharges the high voltage post haste. All the best, Tom
Old 08-11-2016, 05:28 AM
Many thanks all! Many Australian black and white TV sets of the late 1950s and early 1960s had a spot suppression/swallower circuit as tom.j.fla suggests above.
Old 08-11-2016, 09:23 AM
Olorin67 Olorin67 is offline
You could always turn the brightness down just before yu shut it off.
Old 08-11-2016, 11:58 AM
I had an old 27" short neck Maggie that used to do that. IIRC I concocted some RC combo on the grid or cathode that would charge up and then after shut down would discharge slowly but keep the tube fully cut off. Pretty simple from what I recall. Pretty sure the reason for the spot is a tube that is way past its prime from reading about it.
