That's a very nice set and hallicrafters sets don't pop up everyday. If you've done radio repair, than you can repair a tv with a little help. The obvious difference, is be careful with the high voltage areas. I've repaired many tvs, but still need help from time to time. I think we all do from time to time, that's why this site is so great. Test the CRT, but many crts test weak after sitting dormant for a long time. Let it sit in the tester a little while before giving up on it. I've had many sets with weak crts, still produce a watchable picture. Absolutely replace all of the electrolytics first before doing a slow power up. Once restored, that should be a nice set. Great find!
Yes, you could, but I'd replace all of the capacitors and then do a power up. You can get a cheap CRT tester on eBay for $20-40. I haven't run into too many 10-12" crts that were completely dead, so you can just recap it and see if you get a raster. Just make sure you pay attention to the electrolytics. If you're just beginning, it's easy to think all electrolytics have one side going to ground, because in most radios that's the case. Any tubular, black cardboard electrolytics are not grounded and must be wired identically the way they're laid out. Ask any questions you have, the guys on here are very knowledgeable and helpful. When disconnecting the chassis after each power up, ground the second anode connector, before disconnecting from the side of the picture tube. Otherwise you'll get a pretty good shock.
