Old 10-09-2016, 11:58 PM
TinCanAlley's Avatar
That ones a little different than the common Arrow-Hart type.
The original wire used was probably cloth covered rubber single conductor stranded wire. One for antenna, one for ground.
When I would see console radios at the Goodwill, many times, they still had that type of plug connected to the antenna and ground wires.
It was great, when the radio had to be moved for cleaning or decorating, but it always seemed the the radio always to be in the same location.
I think they might have been custom. The outlets in the building are Leviton, but the covers have a design around the edge that I can't find anywhere. I've searched high and low, but never found another to replace broken ones.
The wire used in the wall is 14ga. I guess they just used standard electric wire. As for the wire for this plug, I'm guessing it was around 16 - 18ga?
Old 10-10-2016, 10:36 AM
The receptacle pictured isn't a Leviton. The plates possibly are.
Even when that home was built, the wiring, rough and finish was done per bid. That home, possibly had a up-grade wiring job.
I'll look, the next time I go to the HFH Restore. Many times, they have the kind of plates you're looking for, but someone seems to be buying them up, probably to E-bay them.
Old 10-10-2016, 12:44 PM
Yes, you are correct. The switches are Leviton, the outlet is Mohican. The wall switches are ceramic with some having the ability to disassemble. This comes in handy to rebuild them if possible.
These are actually in two (close to twin designed) apartment buildings. For all the outlets they ran a black and a white. For the aerials, they ran blue and red. For the age, the wiring is in amazing shape. It isn't brittle at all and you can feel the rubber texture of the coating.
Old 10-10-2016, 08:06 PM
Mohican Relyon was the lower priced line of Arrow Hart&Hegeman.
Is the building wired in BX cable or knob & tube. Some areas used old style Romex without a ground, which had a woven cloth cover.
Old 10-10-2016, 08:40 PM
For the lower priced line, they sure have stood up to years of use. A few were replaced due to wear as they just wouldn't hold a plug anymore. Others were replaced with 3-pronged for refrigerators and such. About 70% still are in use.
The buildings are BX cable with the rubberized wire. That's some pretty heavy conduit as it's steel. The wiring from the outside is on some massive sized wiring (not sure what gauge, but each handles 400 amps).
There are some knob and tube in the attic, but it is stringing the wires for door bells and there's a central power supply behind a panel in the second floor hallway. The doorbells are long gone, but the wiring is still there. I found the transformer in the wall was still live, so I disconnected it.
It's fun going through these old buildings. I found an empty bottle of bourbon in a dried puddle of plaster in the crawl space under one of the buildings. I was able to clean it off without too much damage to the label. I had a date of '38 on the bottom.
Old 10-10-2016, 09:22 PM
My coming here has brought me luck. I just purchased the following from ebay. I don't need the outlet, but the cover plate is an exact match for the original of the aerial plug and matches the wall switch and outlet cover plates. This is the first time I have found a cover plate that matches what is in the buildings. I guess that since switches get used regularly, the plates get damaged more often and are replaced. Too bad I haven't found any of those yet.
Old 10-11-2016, 11:35 AM
That single receptacle should be a Leviton.
Regarding the Mohican Relyon devices, I lived in two old homes that had them and they still held the plugs alright. I wasn't about to change them, as we didn't own the property.
Many old homes had a built-in-the-wall ironing board and they always seemed to have a single receptacle nearby. ???
Old 10-12-2016, 03:38 PM
Banned
In reguards to those outlet and switch covers you are saying that you are having a hard time finding those are Leviton and are from the 1940s and 1950s, the church I grew up in had pretty much every single outlet and lightswitch in the building utilizing that particular outlet and switch plate style with that exact pattern, except they were black and not white, anyways I'd say that was actually a fairly common switch and outlet plate pattern (even my grandparent's old house had some switch and outlet plates like that in there), probably the reason why you aren't finding them is because the ReStore is probably selling out of them before you can get to them because lots of home rehabbers are buying them up for fixing up their period home, because I know that at my local ReStore I've seen those type of switch and outlet plates all the time there, I just don't need them so I don't buy them, but they are around you just need to hit up the ReStore at thet right time.
Good luck.
