The Zenith/Bose set with chinese cabinet
Deciding whether or not to fix. Fired it up for the first time since I picked it up. After running awhile, didn't look to bad. Sound was good. Pic is raised from the bottom and top is stretched. Is there a certain set of caps I need or will I have to just check to see? Anything else an issue?
Genesis does what Nintendon't Last edited by pac.attack76; 04-19-2024 at 09:19 AM. |
That's sweet. Definitely fix it. Unique cabinet, Bose...that's a rare set.
Yah, that's a keeper. Probably a simple fix.
Change EVERY electrolytic cap on the vert module & check for
cold joints. The vert IC has been NLA for yrs so you dont want it to blow over a few bucks worth of caps! Also go over the power supply & HV modules for cold joints & swollen 'lytics. CRT looks fair with some red bleeding. Running it & adjusting it "down" a little will help. This is a "Digital System 3". after the video detector everything is digitalized for processing. This model is VERY rare & the most expensive in the line. If a 27" would have been $1,500- $2000. A non Bose 27" table model DS3 was $1000...... Please keep it & keep it intact !!!! BTW "digital" sets like this using the ITT chip set were also sold by NEC, Toshiba Panasonic & maybe MGA. Zenith sold by far the most from 20" to projection sets. 73 Zeno ![]() LFOD ! |
I'll definitely be fixing then. Soon as I get into it, ill go over everything.
Genesis does what Nintendon't |
I like it. Unique. Try to get it repaired.
Looks like pincushion issues too.
With so many projects, I'm just now getting around to this one. September 1986 model. I took these three pics. If anyone can point me in the right direction of what needs replacing and what needs touching up. One will be checking under the plate below for caps, etc. Not sure where the vertices section is on this one.
