Change EVERY electrolytic cap on the vert module & check for
cold joints. The vert IC has been NLA for yrs so you dont want it to blow over a few bucks worth of caps! Also go over the power supply & HV modules for cold joints & swollen 'lytics. CRT looks fair with some red bleeding. Running it & adjusting it "down" a little will help. This is a "Digital System 3". after the video detector everything is digitalized for processing. This model is VERY rare & the most expensive in the line. If a 27" would have been $1,500- $2000. A non Bose 27" table model DS3 was $1000...... Please keep it & keep it intact !!!! BTW "digital" sets like this using the ITT chip set were also sold by NEC, Toshiba Panasonic & maybe MGA. Zenith sold by far the most from 20" to projection sets. 73 Zeno ![]() LFOD ! |
I'll definitely be fixing then. Soon as I get into it, ill go over everything.
Genesis does what Nintendon't |
