Old 11-07-2016, 10:14 AM
The cabinet turned out great, it's just very hard to photograph something that's very shiny. Most clear plastic's become cloudy with age, especially if they've been exposed to high levels of sunlight over a long period of years. I doubt it will be a problem once you have the CRT lighting it from behind, at least not in a low ambient light room.
Old 11-07-2016, 11:23 AM
I always used to use "Pledge" furniture polish on the plastic lenses on the 50's type portables. It seemed to fill in the minute scratches and improve the clarity.
Old 11-07-2016, 01:53 PM
I'll try some of that. Thanks.
Old 11-07-2016, 02:25 PM
But don't EVER use Pledge on (or near) any old wooden cabinets. The silicone can permanently contaminate the finish and then you may have a heck of a problem if you ever want to refinish it. Google "silicone contamination" to learn more.
Phil Nelson
Phil's Old Radios
Old 11-07-2016, 04:36 PM
Phil Nelson
Phil's Old Radios
Good point Phil!
Old 11-07-2016, 10:57 PM
Today I finished up some small details and mounted the chassis back into the cabinet. I still have to polish up the knobs, make the back, redo the labels, and add some longer speaker wires. Getting real close.
Old 11-08-2016, 10:30 AM
Just an update on the alignment.
I decided to check the tuner and work back through the TV. When checking the tuner on channel 3 it wouldn't align. The frequencies were too far off. I then decided to check channel 4 and sure enough the freq. were much closer, so I decided to use channel 4 instead of channel 3. Channel 4 aligned perfectly with the waveform and frequencies where they should be.
Then on the the IF section. Again the IF section aligned great with a correct waveform and on frequency.
I used a meter to align the first step in the 4.5mc audio section. But the 2nd step didn't work out so well. I never could get the meter to zero out. I hooked up the sweep generator and o'scope and peaked per step 1, but never could get the cross over pattern in step 2. I ended up just tweaking by ear.
Oh, I also used Wallace Teleaides to check the run updates and some cures for other problems. Looks like my TV is from run 5 and I installed the retrace mod, both vertical and horizontal picture was too large so I followed the steps to reduce those. I added some resistance and shorted out another resistor.
All-in-all the TV is playing very well. The picture tube isn't as bright and clear as I would like it, but it never did test into the green very far. I'm happy with the results so far.
Stay tuned for final pictures and report.
Thanks.
Yeah, mine has become a little cloudy. However, there is a casting flaw in it just like kvflyer has in his.
