Old 12-04-2016, 12:01 PM
Doug Doug is offline
need help identifing this radio
no name or numbers,, doesn't have a back, nothing on the bottom, didn't see any numbers on chassis
Thanks
Old 12-04-2016, 06:57 PM
mr_fixer's Avatar
mr_fixer mr_fixer is offline
You know, the lack of writing on this radio and the unusual dial makes me wonder if this was a early radio set for the blind.
Old 12-04-2016, 07:28 PM
Behind the aged plastic there is a dial
Old 12-04-2016, 08:53 PM
Dial mech reminds me of Grunow Teledial sets.
Old 12-04-2016, 09:02 PM
I was thinking the same thing, although I couldn't think of the manufacturer's name at the time. The preset tuning adjustments rang a bell in my head, though; I knew I had seen this type of radio before. There was only one manufacturer (that I am aware of, anyway) that used this kind of preset tuning setup, but for some reason Wards Airline came to mind. Could this radio have been built for Montgomery Wards by Grunow, and sold under the M-W name? I think it must have been.
Old 12-04-2016, 09:56 PM
Findm-Keepm's Avatar
Followin' the Rules...
Thanks
Any tubes in the unit? With a tube complement list, you could use the search function over at radiomuseum.de and see what it comes up with....
Brian
USN RET 22YRS (Avionics/Cal)
Old 12-06-2016, 09:48 AM
sean's Avatar
sean sean is offline
Check out PDF page 16 of this section of the Mallory-Yaxley Technical Manual. The Trav-ler automatic tuning system looks just like what you have.
http://www.vacuumtubeera.net/AutomaticTuning.pdf
Here's a model that looks similar to yours.
http://www.radiomuseum.org/r/travler_627.html
Sean - WØKPX
Old 12-06-2016, 11:32 AM
You nailed it - it's a 527, apparently:
http://www.radiomuseum.org/r/travler_527.html
http://www.americanradiohistory.com/...m the small%22
Cheers,
Brian
Old 12-09-2016, 09:40 PM
I appreciate everyone's help..
