Or with a single transistor:
Video Inverter near the bottom of the list..... http://www.hobbyprojects.com/A/video.html I built a crosshatcht generator using an EDN magazine "Design Idea" and tried the video out with a salvaged Astec modulator - no joy, so I rigged up a 2N2222A as an inverter, and voila.... BTW, it still works, and is more stable than my RCA portable unit...
Brian USN RET 22YRS (Avionics/Cal) CET-Consumer Repair and Avionics ('88) "Capacitor Cosmetologist since '79" When fuses go to work, they quit! Last edited by Findm-Keepm; 12-08-2016 at 09:23 PM. |
![]() Would a 2N4401 work in that circuit?
John |
Sure - any low gain (hfe<500) NPN should work. If you get any ringing, try ferrite beads on the base and collector leads.
I built my 2N2222A inverter on a double sided PCB, with the bottom as a ground plane, and "Manhattan" style construction on the top. The circuit I used was in "Circuits Cookbook" from 1967.... The whole circuit takes advantage of the common emitter configuration for inversion - and - the common collector configuration gives you the non-inverted video on the emitter. Two in one! https://en.wikipedia.org/wiki/Common_emitter https://en.wikipedia.org/wiki/Common_collector
Probably need some gain
Can anyone verify that the circuit I posted should work? I can't get anything out of it.
John |
Or, if the emitter/base voltage is too high, the transistor will overconduct and saturate. So lower the voltage by increasing value of the base-to-12V resistor. This is all assuming the transistor is NPN silicon type and supply is +12V. BTW, the circuit shown will deliver only half the output level that it would if the non-inverting feature (which you don't need) were eliminated. The mod would be easy to do if the output level turns out to be inadequate. Here's a neat little tutorial on transistor biasing.. http://www.electronics-tutorials.ws/...r-biasing.html Last edited by old_coot88; 12-11-2016 at 01:07 AM. Reason: Typo |
How would I accomplish that?
John |
You could try leaving the lower base resistor as 4.7k and increasing the upper one to 15k or 18k. |
I always use a pot...
say 100K or so and adjust it till I get what I want with a scope on the output. Then measure the pot and substitute fixed resistors.
