Old 12-17-2016, 09:21 AM
Between the 6 Instruction Sheets and the IF Strip Instruction Sheet, there are 280 individual steps!
103 have been completed.
Old 12-17-2016, 10:57 AM
A slightly related question?
Were did you source your replacement parts, all from Radio Daze? I really like the resistors you're using. The caps are similar to the ones from Jim's Antique Radios, they seem alright!
BTW, I wrap and crimp the component leads very much the same way you do before soldering. I was taught, "Mechanically and Electrically Secure".
A buddy asked, "Why do you do it that way, it's overkill". IF it's soldered properly, you don't have to do that.
Old 12-17-2016, 12:19 PM
I get my parts from Just Radios. Both caps and resistors. Good stuff. Sometimes I get caps from Sals. Good stuff too. I like using the 1W resistors because the leads are thicker and stronger than the 1/2W ones. I like Just Radios because I can get film caps, mica caps, e-caps, resistors, spaghetti tubing, heat shrink tubing all in one stop. I get some stuff like Nichicon e-caps, chassis mount resistors from Digikey
On the lead wrapping stuff. That's the way I've always done it. I have a background in the Avionics installation and repair and we always wrap the lead or wire for that extra security. It is overkill on these TV's but I think wrapping the lead also holds it in place till the other components are attached or till it's soldered.
Old 12-17-2016, 07:15 PM
I finished step 4 (Vertical Oscillator & Output). This step had 39 steps. Things went very well. I lengthened 1 wire by 2 inches. My .0047uf caps did not come in today so I couldn't install C29.
One thing I noticed is that the pre-made CRT connector and yoke wires are too long. Tonight I'll see how long they are and maybe adjust their length. I'll let you know what I found.
Here is an overall picture after step 4.
Followed by some close ups of the area.
Old 12-17-2016, 08:15 PM
OK, first up is the CRT wiring length.
Here is how long it is as of right now.
Here I am measuring 6 inches to shorten the harness by.
Here is the harness pushed into the chassis 6 inches.
It looks like I can shorten the harness by 6 inches and still have plenty of slack. Comments anybody?
Old 12-17-2016, 08:23 PM
Next up is the yoke harness.
Here is a picture that shows how long it as of right now.
And the harness pushed into the chassis 6 inches.
So what do you think?
Old 12-17-2016, 08:30 PM
Findm-Keepm's Avatar
Followin' the Rules...
Man, with a beautiful chassis like that you'd better sign that chassis when you are done - it's "art" for sure. Use a paint pen, no wimpy Sharpie....
Brian
USN RET 22YRS (Avionics/Cal)
Old 12-17-2016, 09:05 PM
If you ever fall in love with an empty cabinet that needs the CRT mounted separate from the chassis the extra lead length could come in handy.
Old 12-17-2016, 09:11 PM
Yeah, it is nice. Thanks.
Old 12-17-2016, 09:12 PM
That's right, I forgot about that option. Thanks.
Old 12-17-2016, 09:26 PM
Blast's Avatar
Blast Blast is offline
blast, blast...
Enjoying this thread. Very cool! Good luck with your build.
Old 12-17-2016, 09:46 PM
I'm glad you're following along. That's why so many pictures and details.
Thanks.
Old 12-17-2016, 09:48 PM
Tom got me thinking about keeping the long wires. So I came up with this solution:
Now, my big question is having both the CRT and yoke wires with a coil in them will that affect the quality of the picture? Anybody know?
Thanks.
Old 12-18-2016, 01:05 AM
Probably not - no significant inductance or capacitance generated - if it was color, perhaps, but B/W, no. Think about Predictas - CRT/Yoke had some pretty long interconnect cables......
Brian
Old 12-18-2016, 10:39 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
That makes me think, Heathkit TVs should have had "builder's signature" etched into the chassis instead of a signature line on the build sticker...
