Enjoying this thread. Very cool! Good luck with your build.
I'm glad you're following along. That's why so many pictures and details.
Thanks. |
Probably not - no significant inductance or capacitance generated - if it was color, perhaps, but B/W, no. Think about Predictas - CRT/Yoke had some pretty long interconnect cables......
I see you still use the time-proven method of using lacing cord instead of zip ties. That's when craftsmen still cared. I see more of those strange Chinese names on the caps, but they seem to be good caps. |
dieseljeep,
Yeah, I still like lacing cord. It's a hold over from when I used to do avionic installations. The only time I used Ty-Raps was when attaching the harness to the airframe, if the OEM did the same. Otherwise it was Adel clamps. Yup, I'll "break out" the yellow wire from the rest of the harness. I got the caps, that I missed with my order from Just radios, from Sal's Capacitors. Very vice caps indeed. |
I worked on step 6 (Horizontal Output and H.V.). I'm almost done wiring. Step 6 went ok also. I did not quite go step-by-step because I wanted to wire up what was down near the chassis before I installed the flyback transformer. It was much easier to do it that way. All I have left is to wire up the HV lead to the CRT and the power cord.
Here are some pics. ![]() ![]()
Here is the HV lead going to the CRT. I used some 20KV wire and a connector and boot from an old color portable TV gotten free from the curb. I replaced the 40KV wire with my 20KV wire and put the 470K resistor in line like the instruction sheet had shown. I double heat shrunk the whole assembly. I also replaced the 20awg standard hook up wire from the 1X2A rectifier tube to the door knob capacitor because it was carrying full HV with the same 20KV wire. The terminal on the tube socket was also double heat shrunk.
I know the instruction sheet shows the resistor directly connected to the door knob cap connector, but I thought using a small piece of 20KV wire which is stranded, it would hold up better to any movement. What do you think? I'd prefer that the resistor was hard mounted to some phenolic or terminal strip but it does look like it'll work. I'm including a picture of the portion of the instruction sheet. ![]()
