Old 12-19-2016, 09:23 AM
The CR70 uses DC to power the CRT filament. DC and AC RMS are basically equivalent. So 6.3 VDC on a CRT filament is just fine. No, your DMM has a very high impedance and will not load the supply down like the filament will. You'll need to measure the voltage while it's connected to the CRT.
You meter might have a static charge built up on the plastic face. Try wiping it with an anti-static dryer sheet like "Bounce"
Old 12-21-2016, 06:34 PM
spacediver spacediver is offline
I tried this, but it didn't work. I've just created a video where I test the remove G1 Short and rejuvenation functions, the bias settings, and adjusting filament voltage to compare the needle with the multimeter. I wipe down the plastic face with an anti-static dryer sheet in the video too.
Here it is.
https://www.youtube.com/watch?v=CSMIkESgn98
Am I doing something fundamentally wrong here? Or is my unit just bust?
edit: I realized soon after making this video that you meant to wipe the plastic face where the needle is. I can be a bit daft at times :p. Nevertheless, does anyone have any suggestions about the other issues with the unit?
