I would only halve the G2 resistor, another one in parallel. All the low B+ larger screen sets I worked on, seemed to use a 25DN6 instead of a 25CD6. IIRC, Sylvania designed the tube for that purpose. It looks like the tube in your set is the old style 25CD6G. After the resistor trick, the first thing I would try is a 25DN6. |
Actually the 25CD6 and 6CD6 are identical except for heater ratings.
http://www.datasheetarchive.com/dl/4...3319916/O/6cd6 Last edited by old_coot88; 12-22-2016 at 12:06 PM. |
I tried another 470 Ohm resistor paralleled with R63 which is connected to pin 8 of the 25CD6. No joy then I added another resistor in parallel and still no joy. The schematic does list a 25DN6 in parenthesis next to 25CD6. |
I have the proper HV probe to go with my VTVM on order. It'll be here within the week. then I'll know for sure what the HV really is.
If nothing else pans out, I would try this as 'proof of concept' for raising B+ voltage feeding the H.sweep circuit: String a few 9V batteries in series, and put this in series with the +130V going to the plate of the damper tube.
If raising B+ improves HV, focus, and width, then consider building a small dedicated supply to put in place of the batteries. Just a thought.
I thought I'd do a voltage check according to the schematic. I found some voltages out of wack!
I started with V15 Vert. Output and went down. Here's what I found. First volt listed is what the schematic says, the second is what was measured. V15 Vert. Output - 3 Plate 125V - 119V 4 G2 130V - 129V 8 Cathode 17V - 15V V14 Vert. Osc. & Sync Limiter 5 Plate 130V - 55V V13 Horiz. Damper 3 Cathode 350V - HIGH VOLTAGE! Blew out my MM which was set at 1000VDC V12 Horiz. Output 5 G1 -25V - -22V 8 G2 125V - 120V V11 Horiz. OSC. & Phase Det. 1 G1 -46V - -41V 2 Plate 155v - 142V 4 G2 20 - -9V 6 Cathode -10V - -6V V15 looks good V14 Plate voltage is low V13 Wow, blew out my MM V12 looks good V11 Pin 4 G2 voltage is wrong Last edited by Crist Rigott; 12-22-2016 at 03:51 PM. |
