Old 12-24-2016, 08:05 PM
Originally Posted by Crist Rigott View Post
Yes, please! Thanks.
After much futzing with a bad SD card; pictures at last!
The audio output transformer is not for sale, and will be trimmed off. The side with the transformer once mounted to a defunct speaker. If you don't want the cloth wire on the other end, then I'd like to keep that wire.
I'd do an even trade for that HV connector/cable you did not use that came with your kit.
PM me if interested.
Old 12-24-2016, 10:24 PM
Thanks for the pictures. Let me think about it for a while. If I did get it, I wouldn't need any wires and such. Just the connectors.
Old 12-24-2016, 10:26 PM
I've had a lot of suggestions from people on the ARF. While good suggestions, there is still no joy.
Everybody's help is appreciated and together we'll get to the bottom of this.
I think what I'll do next is to change out the rest of the caps and resistors that is left to do in the IF strip. Then look at the alignment procedure that is given in the instruction booklet and see if that will help. In the meantime, I might be able to round up another CRT that I could try. Another thing that is on my mind is to remove the CRT base and closely inspect and redo the leads going through the pins in the base.
I should have a good HV probe to go with my Knight KG-625 VTVM in a few days so then I'll know where I stand with the HV.
I just might need a smaller CRT. We'll see.
With Christmas here, my time in the shop will be limited for a bit.
With that I'd like to wish everybody a Merry Christmas.
Old 12-25-2016, 07:27 PM
The focus on the 5AXP4 is much better.
Boost the line voltage another 10 volts or so. See what the focus and brightness looks like then. You installed E'caps, that were rated for higher B+ so no worry.
I just looked at an old Sylvania tube manual for the specs on the 21FP4 and it shows the focus voltage, rated between -200 to 1KV on pin 6. I don't remember seeing, that kind of voltage used for E'stat focusing. It was always between ground and boost.
Old 12-25-2016, 07:59 PM
And if that shows promise, consider sticking a few 9V batteries in series in the B+ line feeding the H.out circuit. That would give it even more grunt, B Boost and HV without overstressing the heater string.
This would at least give a yes/no whether raising B+ further on the H.out circuit would help.
The battery string would go in the B+ line feeding the plate (pin 5) of the 12AX4. If it helps, then consider building a small dedicated supply in place of the batteries.
Just a thought FWIW.
Old 12-25-2016, 08:25 PM
P.S. If you're interested in trying the 9V battery trick, I have a ton of them which are pulls from smoke detectors in my building. They are Mallory Duracell and all test well into the green on a standard batt. tester. The pulls are always good since they're changed on one-year interval.
Free for postage. PM me if interested. Bill
Old 12-25-2016, 08:47 PM
Here is a video of the picture quality. The picture is a lot more focused just after turn on but then looses focus after that. Watch the SUN day of the weather to see what I mean.
https://youtu.be/DXsw8_pofTA
Old 12-25-2016, 08:50 PM
I could boost the line voltage by 10 volts. Would that hurt the filament string?
Old 12-25-2016, 08:53 PM
OK, it's worth a try. What, like 27 to 36 volts?
Stand by for preliminary tests.
Old 12-25-2016, 09:10 PM
The raster shows some 'hourglassing' from powerline ripple causing the slow bend on the sides that drifts up. What's the value of the two main filter caps (right after the rectifier)? The second one may need to be bigger to get rid of the ripple.
I forgot to mention using a Variac. Many will put out 140 volts.
You can boost the B+ by using a 12V heater transformer, rated at around an amp, connected boost. Connect it before the rectifier and you'll just increase the B+, without increasing the heater string.
Old 12-25-2016, 09:32 PM
Both are 220uf
Old 12-25-2016, 09:33 PM
OK, I can do that.
Old 12-25-2016, 10:11 PM
OK here is what I did. I connected a 20 ohm 25W resistor in series with the heater string. This allowed me to increase the B+ from 124V to 135V. Going from 124V to 135V the picture just got bigger and not any clearer. My variac could only bring the mains up to 132vac.
