My distribution amp is a Radio Shack, four output unit, a thrift-shop special. |
Where Bob's at if he had Zenith boxes he could probably dispense with the antenna system altogether, and get the same reception with a few inches of phone outlet hook up wire plugged into the center of the boxes antenna jacks...
The Maggies are bad enough, the RCA's are no prize either! And those GE camel-back jobs, forget it, unless you're living on east Capital drive.
I have never been able to get decent tv reception, even back in the analog days because I actually live so close to the tower park that I am in the shadow of the towers. The signals are full of reflections due to aluminum siding on both my home and my neighbor's house who is between me and the towers. Now for the real kicker. My house is aluminum sided and has a metal roof. The metal roof and aluminum siding attenuate signals to the point that I have to stand by a window to get 1 bar of signal strength on my cell phone. Cell phones are pretty much useless in my house. 1 mile NW of my house is another tower park where channel 12 and 58 broadcast from. I can't receive any of those signals at all due to the metal siding and roof. Currently my antenna is inside on the ceiling of the tv museum but I am considering relocating it to the outside to get a stronger signal without interference from the metal roof and siding. I will take your word about the Magnavox box not having sensitivity as good as the Zenith. I have no experience with the Zenith boxes. However, in my situation the fact is that you can't get something from nothing. My Magie boxes work quite well if I connect only one box directly to the antenna. If I split the same minimal antenna signal, using a passive splutter, into 4 feeds to the converters, the signal drops too low to be of any use. Therefore a distribution amp is required. The problem is not the Magnovox converter boxes, it is the Faraday Cage that I live in.
Vacuum tubes are used in Wisconsin to help heat your house. New Web Site under developement ME http://AntiqueTvGuy.com Last edited by ohohyodafarted; 01-08-2017 at 01:27 PM. |
You need to stop trying to read so far into things looking for digs that don't exist....When I light into someone I try to make it VERY clear what I'm doing. If you are going to insult me for NEUTRAL technical advice/Technological opinion then I shall refrain from responding to your future requests for such advice. I was initially going to razz you in this post (you certainly asked for it by derogatorily referring to me as arrogant with NO real basis), but I'm not going to be goaded into stooping to that. I'm going to let this slide, However...Future unprovoked attacks from you such as this quoted post will result in a ban of a duration commensurate with the severity of such future behavior. You have been warned.
Dear Mr. Carlson,
In the first place this thread was a request from a poster about how to split his signal from his antenna to 4 tv sets. The correct answer was to use a distribution amp. Using a 4 way spliter is almost always a crappy idea. This thread was not a discussion about the brand of converter boxes to use. If you wanted to be of some help, you should have adressed the poster's original question on how to split his signals properly. Quote:
Any time you refer to someone by name, you are getting personal. You mentioned me by name referencing issues that you had no first hand knowledge about. When you start talking about someone's personal situation, and postulating about things for which you have no first hand knowledge, that qualifies as arrogance. Quote:
And now, (being as you seem to feel I made bad choices in construction materials), a lesson about zoning codes and construction materials. The house I live in has had aluminum siding since 1955, 4 years after it was first constructed. It was installed over 8" wood lap siding when, after only 4 years, the paint started to peel. Rather than spend money to repaint after only 4 years, aluminum was installed over the wood, which over the next 60 years has probably saved thousands of dollars in repaint costs. The home of my neighbor to the south, was constructed in 1948 3 years prior to my home and had aluminum siding right from the start. After having re-roofed my home 3 times during my life(once due to fire), I decided that I would never again spend for shitty conventional asphalt shingles, and 4 years ago I installed a lifetime, premium quality metal roof at only twice the cost of asphalt shingles. A metal roof and aluminum siding also gets me a small reduction in home owners insurance because it's also a great fire retardant. Can't say that about other building materials. Have you ever seen how vinyl siding melts and catches fire if the house next door is ablaze. Maintenance free materials like a metal roof and aluminum siding also add great value to a home should you decide to sell. Most people who re-side their home use vinyl due to the very inexpensive nature of the material. Vinyl is about 1/3 the cost of aluminum and quality wise you always get what you pay for. Vinyl has a couple distinct disadvantages. First and foremost it has a very large coefficient of expansion. It has such a large CE that vinyl siding has to be installed in a "floating" fashion with room at the ends of each row for expansion. During the summer as the sun heats the vinyl, you can hear vinyl siding expanding and conversely as it cools in the evening as it shrinks. Even worse is the fact that in our extremely cold Wisconsin winters, the vinyl gets very brittle. If it is struck with a blow from an object such as a snow shovel it will crack and shatter. Aluminum siding has none of these disadvantages. Most municipalities, have some sort of building codes that you must conform to. The Village of Whitefish Bay also has an architectural review board that governs the esthetics of your project. In fact if WFB could, they would probably regulate what kind of paper I wipe my butt with. In the case of the two story garage that was built over Bob's Bunker, there was a requirement that the siding be an exact match to the existing siding on my home. The same was true of the roof. The building code also regulates such things as the style of the corners that are used on the siding, the esthetics of the windows, the style of the roof line, and dozens of other esthetic issues that must meet code requirements during the design phase, prior to the granting of a construction permit. Instead of commenting on, and jumping to conclusions about things you have no knowledge of, perhaps you should have just asked a simple question "Bob, you are very close to the transmitters, what is the reason you have a need for distribution amps?" That way I could answer you in a detailed informational manner, and you wouldn't be calling me a paranoid jerk who made poor choices of building materials. Quote:
Vacuum tubes are used in Wisconsin to help heat your house. New Web Site under developement ME http://AntiqueTvGuy.com Last edited by Electronic M; 01-09-2017 at 02:12 PM. Reason: removing part where you've gone too far-YOUR REALLY PUSHING IT! |
I honestly never wanted to set you off or argue with you in the first place...And honestly I could not give a damn about what we are arguing about. You seem to want to argue with people for sport, (many deleted inflammatory posts and threads you've made often for no good reason/not in reply to anything attest to that), and read insult into places where none exists...I'm done arguing with you here as of this post (I've got enough crap in my life/better things to do) next time you dis-respect and insult me (as you've done here) will result in posts disappearing and a posting time out.
If you are bothered by topic shifts being allowed/common I suggest you start a separate topic for it. Says the one who called me arrogant first! If I wanted to do name calling there are dozens of good ones that would curl your hair that I can come up with at a moments notice, and choose not to use...What I called you is what you appear to me to be. Quote:
But seriously, if you say that your (and your neighbor's) roof and siding material are CAUSING multipath reception problems then clearly you are stating that it was a poor choice of material for TV reception....I merely summarized it for you. Perhaps I should not have assumed the initial choice was yours (though your siding looks so good that I'd have never guessed it as being as old as you say), however I'd immagine you could have chosen to replace it with a different less reception impeding siding at some point in the time you've owned the place if you saw value in doing so. Quote:
Multi path can occur ANYWHERE (and is assumed to be separate of general average signal strength)...If I had a neighbor that had a roof antenna, and was so inclined, I could put up a small (to the neighbor's knowledge randomly placed) piece of fencing that would jam their TV reception in these conditions through multipath reflection signal cancellation at the antenna. I was using your region as an example of a location close enough to high enough power stations that (ignoring potential multipath) should have enough RF signal strength for a very sensitive DTV box to do well with a bare minimum antenna. Hell, another member even noted my post about using phone wire as antenna as being a "clever observation" before you inexplicably got but hurt over it... Quote:
![]() If you can stop being rude and disrespectful by calling me things like arrogant, then mutual respect will naturally follow. I generally respect people (good natured jokes aside), until treated rudely (such as you did in post 10) at which point I respond honestly and to an extent of rudeness that approximately matches what I've received. Also FYI when older folks claim their experience should be the very last and only word with validity it can and often is seen as a form of arrogance (by those who are younger). I do respect and value the knowledge and opinions of my elders on things they ought to have experience with above some random younger Joe, but I value no one's knowledge above my own (I'll certainly check if told I'm wrong on a fact), and that which is in print...It is my right as an adult American citizen to think, hold oppinions, and value sources of information in any manner I like (just as you have the same right). I'll also call question to others' facts, knowledge, authority, and sanity, or just ignore them if and where I see fit to do so (on a case by case basis) as is my right as an American. If you don't like where I stand you are free to make a polite logical rebuttal, or a rude one (as long as you understand your rudeness will be justly reflected back like a TV signal off of aluminum ).I take crap/rudeness from no man, and put up with it only when it suits my interests. Quote:
The goal of my initial statement was merely to state what I feel could be done with a given box in a geographic region with comparable signal strength to what easily obtained info indicates yours ought to be. Bob! Had you not inexplicably blown up and insultingly called me arrogant and ridiculed me (instead of politely, factually informing me of the difference between my perception/estimation and reality, as you SHOULD have done) I would have never called you a "paranoid Jerk"....The paranoid part is because I can not see what in that initial post could possibly get under your skin at all let alone as badly as it seemed to...So I see that as you making a paranoid projection of a false image of me/my demeanor in your mind onto a neutral, polite post I wrote. I said Jerk because what kind of person tells another they are arrogant and disparages them publicly in such a manor as your post calling me arrogant did?...I think you know the answer. Yes, but it loops back to you since you started the rudeness and provocation, that caused me to respond negatively to you that in turn caused your quoted reply.....You made a gratuitously mean agitating post out of the blue. What kind of reply do you expect from someone who is annoyed at being randomly insulted by you?
So the next time you make comments where I am involved, I respectfully request that unless you can take the time to sit back and carefully construct your thoughts, with the goal in mind that your post may be interpreted in a negative manner; then you should consider not posting at all. In fact please, just do yourself a big favor by not commenting on anything where I am involved. Because if I read something you post that involves a post that I made; and I find that post personally offensive or disparaging, I will be sure to call you out on it. There is an old saying that discretion is the better part of valor. So with that in mind I shall end this dialogue unless you decide to continue deriding me.
Vacuum tubes are used in Wisconsin to help heat your house. New Web Site under developement ME http://AntiqueTvGuy.com Last edited by ohohyodafarted; 01-09-2017 at 04:15 PM. |
