Old 01-22-2017, 04:29 PM
Tomcomm's Avatar
Tomcomm Tomcomm is offline
Welcome to the 21CT55 club. I would like to see some full screen size, screen capture shots. I assume your included screen shots were thru the full RF/IF systems, right? It would be interesting if you could compare them with your computer monitor screen shots. Seems you have some color aliasing contamination in the small detail. Looking forward to your further screen shots.
Old 01-22-2017, 04:54 PM
Originally Posted by Tomcomm View Post
Welcome to the 21CT55 club. I would like to see some full screen size, screen capture shots. I assume your included screen shots were thru the full RF/IF systems, right? It would be interesting if you could compare them with your computer monitor screen shots. Seems you have some color analysis contamination in the small detail. Looking forward to your further screen shots.
Tom,
In the link I provided, (within the image carasel) you can click on a tab to see the full resolution shots. I used a non-pro camera, an iPhone 6 Plus to capture the shots. The signal was OTA converted to analogue with a converter box. I'm still planning to adjust a bit more and create a video. I followed your treads on the 21CT55 and that CRT produces about the best color CRT screenshots I've seen from an old "roundie". The original CRT (21CT55) was replaced with a newer tube, right?
