Old 02-13-2017, 12:02 AM
So that's a fairly thin, primarily for wood cutting blade? Anyhow it sure cuts smooth, but I'm sure that has a whole lot to do with the saw operator.
Old 02-13-2017, 10:26 PM
The band saw is a Delta 9" table top. I use it primarily for my model airplanes. Usually 1/4 5 ply plywood at the most. Also the blade is fairly new since December.
Old 02-13-2017, 10:32 PM
I'm done with the E-Caps.
I cleaned off the Mallory labels on the 3 tall caps. I then polished C116 can using Mothers Mag wheel polish. Followed by 2 coats of wax.
I then placed the cans on each cap and taped them so the can wouldn't come off when simply removing the cover. I use 3M Multi-Task tape for this. It is not like scotch tape. It goes on smooth and you can remove it in one piece. I use this stuff to seal the hinge gap on my control line model airplanes.
C116, the tall uncovered cap, the can is simply placed on the base. It is protected from getting all scratched up.
Here is a picture of the tape that I use:
Old 02-13-2017, 11:48 PM
Oh wow! You're into model planes? Is there a forum where you hang out? Do you fly stuff other than CL? 'Pologies for the thread hijak.
Old 02-14-2017, 01:57 PM
I hang out at "Stunt Hangar".
Here is a link to my latest build. It is a control line stunter. I fly stunt in competition. We are judged on how well we do mandatory stunts like loops, squares, triangles, figure 8"s etc. We are also judged on well the airplane is built and finished.
http://stunthanger.com/smf/gettin-al...ter-build-log/
I also fly some R/C. Here is a link to a build log on my Falcon 56.
https://www.rcgroups.com/forums/show...-Scratch-Build
Old 02-14-2017, 02:06 PM
I'm cleaning up the yoke mount today and noticed that there is some black paint looking stuff under and aft of the rubber bumpers for the CRT. I thought it just might be some black paint at first. Then I thought why would they paint that area black? It doesn't make sense.
Then when cleaning it off, it seemed to be almost rubbery? Then I remembered that when full sized airplane have rubber deice boots installed, we used to apply a small amount of black conductive paint to the boot and overlap on to the aluminum. This was used to conduct the static electricity built up on the rubber boot during flight to the airframe where it can be disapated off the airframe through the static wick dischargers.
Do you think that what this stuff is?
Here are 2 pictures showing what I mean:
