Welcome to VK!
I have almost that EXACT Zenith and an identical Silvertone roundy (plus a second similar earlier Silvertone roundy). My Zenith is a 12B13C52 chassis (may be covered in the same sam's) in the same cabinet (which was called the Boyden BTW). That Zenith can be a real work horse...Mine has been my main TV for 8 years (of heavy service), and aside from small occasional maintenance (focus divider, tubes, a couple of vert stage caps, the H out tube socket) it took the kind of workload that would age an SS TV. I'm currently trying to figure out an HV issue that brought it down a few weeks back. Is the service switch on the back in the "normal" position? If not flip it there. Get a NOS vertical output tube and vert osc. tube (IIRC they are separate tubes in this chassis), there are a couple of lytics in the vertical that are suspect. When I get home I can post up a picture of the vertical section of the sam's provided my sam's covers that chassis, if not I believe I should have a Zenith issued print of that set's schematic (I have a fairly complete collection of Zenith color TV service lit). Would you like a set of legs for it? It was originally a legged console, and I happen to have a spare set of legs. BTW: best way to work on the under chassis is to flip the set on it's side (make sure at least 2 of the 4 chassis mount screws with the nickel sized washers are installed first) and remove the bottom metal panel.
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 03-07-2017 at 08:45 AM. |
