Old 03-07-2017, 02:26 PM
Put the right resistors in, check and if it is still not right loose the ceramic caps, then check back.
I had the right resistors in as they were at 10.55 meg so I mistook the colors on the resistors and changed them but I put in 1 meg so putting them back won't solve it. I'm just not sure if these caps alone would do this, although I have one tubular on one side of the verticle and ceramic on the other side. The horiz has both exact same ceramics in but that's fine so maybe the mix between the tubular and disc maybe throwing it off. I didn't order the right caps yet figuring I could use these to get the set running.
