Old 03-07-2017, 02:40 PM
Horizontal runs at a much higher frequency so you can usually get by with ceramics. Ceramic will definitely give you problems in the vertical unless you use a much larger value then specified.
Tom used 0.01 uF caps with good results.
You can read all about it here: http://www.videokarma.org/showthread.php?t=260749
