Old 03-09-2017, 03:02 PM
Is one of the caps in the vertical ceramic ? It's capacitance will change when high voltage is applied causing problems. That's why you should use film or a ceramic cap much larger than what is called for. Swap the two caps around and see if the problem changes.
