Old 03-10-2017, 05:37 PM
I belive that the 20k, 520ohms indicates a range of readings possible, depending on the setting of the horizontal size control... 2.2k is within that range.
As far as the high voltage on the plates of the vertical output tube is concerned, my guess is that your under voltage rated caps may be leaking CRT deflection high voltage back to the output tube (6SL7).
Until you replace the mis-matched under-voltage caps that you have in the vertical output circuit, all bets are off.
I have one correct tubular in there and the other is met film in series made up to 6 kv. With these caps I have in there now I thought it would work for now since I didn't order the rest of the caps.
Old 03-10-2017, 06:14 PM
What is the value and voltage rating of each of the caps in series?
Old 03-10-2017, 06:28 PM
The caps are 5.6 NF at 2 kv each. I have them in series to make up just about the equivalent of a .0047 6kv. My Dvom measures caps this is how I was able to do this, measure the asc cap I have and this is how I got the result using the others.
Old 03-10-2017, 06:53 PM
You would have to have 3 in series to make a 6 kV rating... 3 5.6 nF in series would only be about 1.8 nF. Do the math, something is wrong in your configuration.
Old 03-11-2017, 06:30 AM
kvflyer kvflyer is offline
At the risk of sounding like a jerk, this is what you need. It's what I use and all I can say is that they just work.
http://www.justradios.com/ASCcapacitors.html
