Old 03-14-2017, 12:57 AM
EdKozk2 EdKozk2 is offline
Tinker
That gunk on the antenna wires could be old grease from the clock motor dripping over the years.
Old 03-14-2017, 10:31 AM
The radio's about 55 yo. It's probably plasticizer leaching from the insulation. That nastyness can be cleaned up with a solvent like brake cleaner.
Is the clock running? If not, it's probably grease hardened up in the rotor, the copper colored part in the clock assembly.
Look up "Telechron" on the internet.
Old 03-14-2017, 10:37 PM
Solid_State Solid_State is offline
Wink
Yes the clock runs. I always loved the type of clocks that have a "sweeping" second hand as opposed to the "Tick Tick Tick" every second as battery powered clocks do.
The radio also works it is filthy inside but looks to not had much use. It picks up a few New York AM stations and I believe one Connecticut station
600KHZ 660KHZ and 880KHZ (as checked on a digital tuned radio) I am in the Trumbull, CT area I don't even know the names of the stations I am picking up
I am more of into modern/semi-modern Solid State stuff (Hence my user name) if anything I am keeping it just for the clock
Old 03-14-2017, 11:48 PM
This might help id the stations:
http://radio-locator.com/cgi-bin/loc...req=&sort=freq
