Old 03-16-2017, 01:25 PM
Gleb's Avatar
Gleb Gleb is offline
I could advise you to check the IF transformers with an ohmmeter, you might disturb their pins while recapping. If even one of the windings gets opened, you loose the signal completely.
BTW, I've never seen a bad interstage mica.
To understand a bygone era, you should use things from it
