Old 03-20-2017, 06:26 PM
I don't see a connection on the schematic. I urge you to look at the schmatic and compare it and the wiring in the area of these two pots.
The cap may very well be leaky at operating voltage... Dvom measure of value only will not indicate that problem... if you have an old cap in that location, replace it, and any other old caps in the vertical sync, osc and output circuits.
Old 03-20-2017, 06:53 PM
I am aware that my meter won't check it in operating time so I will be subbing a few caps to maybe weed out a possible bad one. So I checked and good point my mistake it was not separated by the resistors I checked the schematic and it's all in place. Thing is first time on I had vert then it was gone so it may be a cap I hope. And there are no old caps left all changed and also all the Micas in the verticle and horizontal.
