Old 04-01-2017, 11:01 PM
[post edited Apr 9 2017 (new photos)
I totally remembered last night that there was another vending machine hiding away somewhere nearby.
Back in the 90's one of the smaller ski hills closed down. The place was basically boarded up and left to sit. Over a decade ago I wandered through the outbuildings and in one behind the lodge there was a small automat-like machine. Kinda like those refrigerated ones with the carousel that you spin until you see your selection, then insert the required amount, opened the door and pulled your item out, only this one was much more compact and the carousel was coulmns that spun around on an oval looped chain. The whole thing is slightly wider than the Pepsi machine but seems to be otherwise the same height and depth.
I remembered someone had smashed the front window but it seems in the following years someone though that perhaps 20 years on they might of left money in the machine and did a hell of a job on the door around the latch. This allowed critters in and there was a nest next to the compressor. If the wiring wasn't color coded I'd consider this a total loss but I'm willing to take this as a challenge. Seriously considering my options.
