Old 04-12-2017, 09:41 PM
Hey Crist I had a question about laying the Veneer.
I believe you said you overlapped the seams by 1/64" and then sanded them?
How does that work exactly, does the edge sticking up just drop into place as you sand through it?
I've always tried butting the edges together, but that's difficult if they're not completely square.
With the overlap, I then take one edge and butt them together and then run the iron down the seam forcing them to butt together. The sanding comes when the butt joint doesn't lay down completely flat.
