Beautiful point to point wiring. Were these TVs made in Russia or East Germany?
In both countries actually, but in Russia the production had discontinued earlier, in favor of some new 12" tabletops. I described the production issues in the beginning of the post.
The originating designer and manufacturer, the Kazitsky plant, was known for its impressive assembling approach: ![]() That's their 12" tabletop TV from 1953 that I mentioned.
To understand a bygone era, you should use things from it Last edited by Gleb; 04-26-2017 at 04:28 PM. |
Mine is an early German one.
To understand a bygone era, you should use things from it |
![]() I don't see any wax paper caps here. Are they all micas, discs and ceramics? |
That is the distinction! A paper capacitor can be everlasting if it is sealed absolutely hermetically. The white porcelain tubes with the metal caps on their ends, and the grey tubular metal cans, are the paper-type capacitors that don't need to be replaced!
To understand a bygone era, you should use things from it Last edited by Gleb; 04-26-2017 at 04:30 PM. |
I don't see any carbon comp resistors, anywhere, either.
All WWs?
The green rods are carbon film resistors.
To understand a bygone era, you should use things from it Last edited by Gleb; 04-25-2017 at 10:09 AM. |
vts1134, thre's no any news from you. Are you still interested in getting a 23LK1B for your Leningrad television?
This CRT is a dud but I got in contact with a fellow from a CRT rebuild shop and told him your wishes about originality. He's willing to save the original appearance of the CRT as much as possible while rebuilding: to keep the original gun by replacing only the cathode, to provide and guarantee a good lifetime without aluminizing, and so on. But then I lost contact with you; you haven't responded to a number of my emails. We all guess that the rebuild shop won't last long...
To understand a bygone era, you should use things from it Last edited by Gleb; 01-13-2019 at 03:51 AM. |
