Old 05-02-2017, 07:26 PM
robert1's Avatar
robert1 robert1 is offline
I remember those sets very well. i "cut my teeth" in learning how to do TV repairs when i was growing up, on those cheaply made G.E's. i was also servicing them on a regular basis when i was working in TV shops, even well into the 80's
i believe that the model you have has a "split" chassis (two printed circuit boards that are mounted vertically).
these were notorious for bad / broken solder joints (especially under the tube sockets), drifted resistors, & those "ceramic" (paper in a ceramic tube) capacitors. the design was a poor because of heat build up which "cooked" a lot of the components on the circuit boards.
last, but not least, the compactron tube that does the sync separation & AGC functions are usually the first tube to go bad in the set
Old 05-02-2017, 07:49 PM
Check to see that the aquadag (conductive coating) on the CRT is securely grounded, and that there are no isolated 'islands' of the coating.
