Ok, thanks Tom. I'll try that!
I found that if I worked the horizontal lock coil in and out, at certain points the noise would stop. I still have little to no hv though. Thanks for the help guys!
Couple of questions. If you disconnect the plate connector from the HV rectifier, can you draw an 'air arc' from the connector (using a well-insulated screwdriver)? It should draw a nice quarter-inch to half-inch blue arc off the screwdriver. With the connector re-connected, can you draw the same arc?
Is the tube running hot? Last edited by old_coot88; 05-18-2017 at 12:42 PM. |
I cannot draw an arc from the hv rectifier with it connected or not.
I replaced the 3900pf with a .0039uf film cap, but still no hv. I'm starting to run out of ideas on what is going on?
