Old 05-19-2017, 08:57 AM
If you can't draw an arc from the fly lead that normally connects to the HV rect. top connection, when that lead is disconnected from the HV rect then it means the fly is not generating any HV.
Timmy was suggesting that you test to see if the doorknob was loading down the HV...Which is irrelevant at this point because if there is no HV to load down.
