Old 07-18-2017, 07:35 PM
300 to 75 Ohm Adapter
Guys,
I've got some of these adapters and they are cheap. The wire breaks very easy.
What brand do you guys use that has decent sized wires so they don't break so easy.
Thanks.
Old 07-18-2017, 07:44 PM
EdKozk2 EdKozk2 is offline
Tinker
What do yours look like?
Old 07-18-2017, 07:47 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
Channel Master, outdoor ones. I'll get a part number when I get to the basement next (still recovering from a horrendous surgery). Lowest loss balun I've found to date with incredibly thick leads.
Old 07-18-2017, 07:53 PM
SpaceAge's Avatar
SpaceAge SpaceAge is offline
I have a RadioShack one kicking around that seems decent. Ben, hope you get well soon.
Old 07-18-2017, 08:26 PM
Findm-Keepm's Avatar
Followin' the Rules...
We used Channel Master 7282 or 8283's with the UHF leads clipped off - the 300 ohm lead was about 8 inches long, and we used the GC clothespin clips for connecting to the TV VHF/UHF terminals.
94444 is the outdoor balun - and they work extremely well.
I dunno if the 8283 is still made - seems it would've been obsolete in the 90s...
7982's are CRAP.
Brian
USN RET 22YRS (Avionics/Cal)
Old 07-18-2017, 08:28 PM
At the risk of a thread hijack, ditto on the wellness wishes.
Brian
Old 07-19-2017, 08:26 AM
benman94's Avatar
Resident Lunatic
94444! That's it. All I'll buy for baluns, seriously. Lowest insertion loss at any frequency in the VHF range and they are virtually indestructible.
Old 07-19-2017, 08:34 AM
The leads on the average balun should not break unless you are swapping it around regularly....If you are* those 'GC clothespin clips' which are designed to be a quick connect between set terminals and ant/balun twin-lead are a good choice to substantially reduce strain on the wire. I think I still have a couple of spare clothespins floating around if you need them.
*I'd imagine they are breaking at the spade connector, am I right?
Old 07-19-2017, 01:20 PM
Right. At the spade connector.
Looks like the ChannelMaster 94444 is the way to go. My local Home Depot has them for $3 a piece.
Thanks.
Old 07-19-2017, 02:37 PM
benman94's Avatar
Resident Lunatic
I have a box of the 94444s around here. Each restored set gets a new balun and then I drag the coax to it. Way easier than fiddling with baluns each time I move a set, restore another one, etc
Old 07-19-2017, 06:51 PM
Right. That's why I'm looking for some!
