Old 08-04-2017, 12:02 AM
Originally Posted by Penthode View Post
The static convergence pot elements appeared to have shrunk with age on my CTC5. This led to an open carbon element which resulted in intermittent static convergence problems. The shrinkage caused a crack in the carbon element at the rivet where the element was tapped. I ended up using a conductive paint normally used for repairing car window heating elements to bridge the gap on the carbon element.
The paint was applied four years ago and the pot is still fine.
Wow, I never would have expected that's the problem. Thanks!
The proper setting on mine is very close to the tap, and that is the place that's broken. I thought it was due to burning the element.
