Old 08-14-2017, 03:34 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
I have been working on solving a ghosting issue in the picture. Checking resistors on the IF board only revealed 2 out of tolerance resistors. Two 68 ohms coming off the cathode of the 6az8 IF tubes then to ground. Next thing I suspected was the 1n60, but it tests fine on the diode test. Should I still replace it? I need to check around the video amp tubes now.
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
Old 08-14-2017, 04:33 PM
SwizzyMan's Avatar
Found an open inductor on the video out tube. L72 on sams 180 Microhenry 9.5ohm. Is this an appropriate replacement? http://www.mouser.com/ProductDetail/...o%2f1lu29zY%3d
Old 08-14-2017, 07:29 PM
Looks like it should work fine.
Old 08-14-2017, 07:35 PM
Did you check L71 and R68 also?
Edit: also R69, L70, and the contrast control - these are all things that load the input or output of the delay line and need to match the impedance properly to prevent echos.
Old 08-14-2017, 08:11 PM
SwizzyMan's Avatar
Everything tests fine except for maybe the contrast control. It reads 21ohms at full clockwise and about 1k at full counter-clockwise. I dont think that is right.
Old 08-14-2017, 09:08 PM
You didn't say which terminals of the contrast you are connected to, but if you don't disconnect one end, you will read a bunch of other things in parallel, particularly the delay line and its 1.2K input resistor. So, the 1K reading is probably normal or close to it for an in-circuit reading. I would just wait to see what the replacement coil does for your ghosting, rather than disconnecting things unnecessarily.
Old 08-15-2017, 04:30 PM
SwizzyMan's Avatar
Just ordered new coils and resistors. Found another coil that was bad L94 that read about 1 meg when it should be 27 ohm.
Old 08-15-2017, 05:34 PM
Wow that set is going to be better then originally new once it's done, lots of troubleshooting. Looking good keep at it .
Old 08-15-2017, 06:04 PM
By ghosting, do you mean ringing (parasitic amplitude ripples tagging after fine detail in the pic)? If so, try subbing the last IF tube if you haven't already. It can cause ringing even if it tests good on a tester.
Old 08-15-2017, 07:56 PM
SwizzyMan's Avatar
Yes. I believe I did try subbing that tube with no difference.
Old 08-18-2017, 06:24 PM
miniman82's Avatar
First Light: 1952-2011
This can also be caused be improper termination of the delay line, check all parts for value on either end of it.
Evolution...
Old 08-19-2017, 04:11 PM
SwizzyMan's Avatar
So adding the 180uh choke in place of the open one (L72) makes the ghosting WORSE! Ugh! Something else has to be causing this then. Left photo is with no coil, right is with coil attached in circuit.
Old 08-19-2017, 07:12 PM
Suggestions:
1) make sure the value isn't off by a decimal place or something
2) check for open resistor in parallel with either L72 and/or L71
If it's not those, check all other parallel L-R combos in the video amp chain.
Old 08-19-2017, 08:00 PM
SwizzyMan's Avatar
Suggestions:
Value is fine. Checked all coils and resistors that may be in parallel with them and they all check fine except for a coil on the B-Y amp that reads 1.2 meg, but I dont think that one really matters for my current problem. I hope its not the delay line causing this!
Old 08-19-2017, 08:26 PM
Are these components on a PC bOard? Maybe a bad solder joint? Try bridging a resistor directly across the coil?
