You didn't say which terminals of the contrast you are connected to, but if you don't disconnect one end, you will read a bunch of other things in parallel, particularly the delay line and its 1.2K input resistor. So, the 1K reading is probably normal or close to it for an in-circuit reading. I would just wait to see what the replacement coil does for your ghosting, rather than disconnecting things unnecessarily.
Just ordered new coils and resistors. Found another coil that was bad L94 that read about 1 meg when it should be 27 ohm.
Admiral C322C2 Regent (Restoring) RCA CTC-7 Pensbury (Restored) RCA CTC-5 Westcott (Restored) CRA CTC--4 Director 21 (Restoring) |
