Old 08-19-2017, 08:26 PM
Originally Posted by SwizzyMan View Post
Value is fine. Checked all coils and resistors that may be in parallel with them and they all check fine except for a coil on the B-Y amp that reads 1.2 meg, but I dont think that one really matters for my current problem. I hope its not the delay line causing this!
Are these components on a PC bOard? Maybe a bad solder joint? Try bridging a resistor directly across the coil?
Old 08-19-2017, 08:57 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
All point to point wired. Resistor did nothing. I think I will just get the color set up and worry about this later, maybe I'll think of something while Im doing that.
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
Old 08-19-2017, 09:11 PM
SwizzyMan's Avatar
Now on to the color for now. Everything seems to be fine except for colors with magenta. As you can see the magenta bar fades off into red which I attribute to bad phasing in the G-Y(?) channel. I just am not sure how I would fix it (Phasing adjustment?).
Old 08-19-2017, 09:45 PM
it really would help to put a scope on the R-Y, G-Y, and B-Y outputs to see which ones are smeary. It may be the B-Y amp. If all are smeary, it may be a chroma alignment or even IF alignment problem. How is it affected by fine tuning?
Old 08-19-2017, 09:48 PM
SwizzyMan's Avatar
Doesnt seem to be affected by fine tuning at all.
Old 08-19-2017, 09:55 PM
Then you can cross IF alignment off the list.
Old 08-19-2017, 09:58 PM
SwizzyMan's Avatar
Thank god. I will have to hook up the scope tomorrow.
