Old 09-16-2017, 04:41 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Yeesh, never saw a CRT go like *that* before. Oh well, at least it was one with the beginnings of a cataract.
Keep your eyes open for a Zenith Chromacolor II with a 23V CRT, no cataract issues and it should be a drop-in swap. There may be minor mounting hardware issues but that's it. They're relatively common and there are probably a lot of NOS units in hiding considering the 4-lead safety cap fiasco.
Old 09-17-2017, 10:38 AM
Radiophile2001's Avatar
Radiophile2001 Radiophile2001 is offline
Yeah, as I said....ghosts in the machine!....How would a CRT crack like that without some kind of impact?
Anyway, sounds like this one is toast, as far as my skill set goes....!
It was worth a try tho and thanks, all, for the advice on this old Sylvania.
Old 09-17-2017, 12:49 PM
Possibly a poor connection between the HV button and the internal coating of the CRT caused arcing and localized heating around the button, which cracked the glass.
Old 09-17-2017, 01:59 PM
Findm-Keepm's Avatar
Followin' the Rules...
Or someone tried to "pry" out the HV Anode connector. In a hurry, I did it once to a 23EGP22 set. 13 days of worry while the customer mulled over dad's $61 estimate for repair (filter cap, a rectifier and an HV cup...), I'd have eaten a picture tube. In the end, she bought a set at Sears. I got to junk the Motorola, and breathed again.
The crack didn't curve - it was straight as an arrow, to the side I had pried from...
Brian
USN RET 22YRS (Avionics/Cal)
Old 09-17-2017, 11:05 PM
Jon A.'s Avatar
I wouldn't trash it, good 23V CRTs are easier to find than Sylvania tube tabletop sets. Swapping out CRTs is fairly easy, it's the setup adjustments that are tricky.
Old 09-18-2017, 08:12 AM
Cool, thanks....I will not trash it.....although I do not know where to find one....
That set was closed up tight....the room is locked, I don't know how anyone would have touched that anode connector....bizarre...!
