"Pilot Radio" magnifier decal repro?
Does anyone know if the delicate black outlined gold "PILOT RADIO" decal for the optional deluxe magnifier for TV-37 has ever been reproduced? I see that many are worn/faded
Same here. I stabilized mine with some clear lacquer for now but a repro would be great.
“Once you eliminate the impossible...whatever remains, no matter how improbable, must be the truth." Sherlock Holmes. |
Can you safely remove the screws and the glass? If you did, wouldn't it be flat enough to put on a flatbed scanner? I mean, you could use a photograph to reproduce it, but I think scanning it would be more accurate to size and shape.
It is one big molded bubble piece on the front with the flanges and decal on the edge and a flat surface and flange glued to the back side. The filler port is below on the front half. No scanning here.
The way it mounts is with some upper rear clips that hang on the horizontal louvers and a lower bumper post which explains all the broken louvers. It is heavy. Now back to our topic.
“Once you eliminate the impossible...whatever remains, no matter how improbable, must be the truth." Sherlock Holmes. Last edited by Dave A; 10-10-2017 at 10:43 PM. Reason: text |
I see on this website, http://www.vintageradiolabels.com/custom-decals.html ,
that number 11 would look okay in gold, but you really need the black outline to make it stand-out on the bronze/gold background. It's such a great free-form design that it really needs to be repro'd correctly. I wonder if anyone would take on the job. I know I would pay fairly for one. |
Eh.......... I almost want to photoshop it for you, cuz I want to say that it wouldn't be that hard, but like most things, I'm sure it'll end up being a nightmare. Why don't you contact that dude and ask for a quote on a custom designed thingy?
I can recommend Solidesign for creating a custom decal:
http://www.solidesign.bizland.com/decals.html They made decals for my RCA CT-100 TV and other sets. Great work, reasonable prices. I’d take a good close-up photo of the decal that you need, with a ruler by the decal to show the size, if possible. Email that to Scott and ask for a quote. He can clean up the image as needed and print you a whole sheet of decals. You’ll end up with extras, which you can donate to ETF or sell to fellow collectors to recoup your cost. Phil Nelson Phil’s Old Radios https://antiqueradio.org/index.html |
The hardest part of making decals is the art work. The better the scan the easier it is to clean up and get the correct colors or metallics reproduced. I use an ALPS printer for making them.
I just looked at my magnifier and the label is gone, Phil if you can send me a high resolution picture I'll see what I can do and give them to anyone that needs a replacement. Chuck
www.myvintagetv.com Learn from the mistakes of others - You can't live long enough to make them all yourself. |
Sorry, my magnifier has no trace of any decal. The TV came with drawings for building that little magnifier stand with legs, so I assumed it was sort of a homebrew product.
My TV-37 article has another photo that someone sent me, showing a factory Pilot magnifier with a worn decal. I believe it's the same photo that decoejoe67 posted. If you go to this link, you'll find a photo showing a more intact magnifier decal: https://www.worthpoint.com/worthoped...o-3-television Perhaps that image would be enough to work with, if someone could measure a worn decal for width and height. Regards, Phil Nelson Phil's Old Radios https://antiqueradio.org/index.html |
If you're successful, consider one sold already! Many thanks, Joe. |
Ok I hate to jump this post but does anyone have a Pilot TV-37 magnifier to sell?
It's okay, but I wanted to say that you're likely going to have buy one with the TV-37 to get one. There's two factory models. The best is the one pictured above with the decal, and one that has a narrower flange and no decal. Then there's a few aftermarket. I've seen two rectangle models, and one octagon. I have not seen any of them come-up for sale separately at any price for many years. They're all fairly scarce.
It's okay, but I wanted to say that you're likely going to have buy one with the TV-37 to get one as I did. There's two factory models. The best is the one pictured above with the decal, and one that has a narrower flange and no decal. Then there's a few aftermarket. I've seen two rectangle models, and one octagon. I have not seen any of them come for sale separately at any price for many years. They're all fairly scarce.
