Old 10-19-2017, 08:51 AM
user181 user181 is offline
Injecting an analog CATV channel into a digital/analog hybrid system
Be careful your not letting any of your local signal back feed down the line, or you could be interfering with other's service, and the cable co will come down on you hard if you do that
What could/would the CATV company do to come down hard? Would it be anything worse than disconnection of service? I'm not familiar with the laws regarding this, but I'm guessing there could be FCC fines, etc.?
Old 10-20-2017, 07:40 AM
kf4rca kf4rca is offline
Not a problem
A splitter is a directional coupler (with equal loss on each leg). AND they make directional couplers with different values of attenuation in the "down" leg also.
If you are using a splitter as a downstream combiner, there is little or no energy returned to the upstream. It might be 60 db. down which is negligible.
It has to do with the way directional couplers work and the way energy flows thru the toroidal core.
Old 10-31-2017, 09:45 PM
I would be worried about the signal getting out to the street and going to the neighbors TVs.Thats if there is faulty filtered pole equip passing the signals.like said .It could rise issues with the CC and the authorities and content providers if re transmitting TV programming. I would string another line just for that to be on the safe side.
