Old 11-09-2017, 08:47 PM
I started on the main chassis and the E-Caps first. I removed C1 and C3. When removing them, I broke off some of the twisty mounting tabs. This is usually the case. Once is a great while, I'm able to remove a can without breaking them off. These were really twisted!
I'll go into detail on how I re-stuff a E-Cap. Both of these caps are 4 sectioned caps. A while ago I won an auction that had like 25 E-Caps that were 4 sections with the sole purpose of using them as "donor" bases.
Here are the 2 caps and their donors.
I cut the originals as close to the base as I can with my band saw. I use a piece of 1/32 plywood as a shim to prop up the can because the base is larger in diameter. As I cut with the band saw, sometimes I'll rotate the cap some just to help keep the cut straight.
Here are the results of cutting the originals. All I'm interested in are the "cans". The bases are no good to me.
After removing the cardboard covers using my heat gun, I then cut the bases off the donor caps. This iime close but not so close to the base as with the originals. Here are the results:
Notice how much fuller the original cans are compared to the donors. Here is a picture of the original cans and the cleaned up donor bases. I clean up the bases using a brass brush and then drill a 5/32 hole in the middle. These holes were offset slightly to avoid drilling through the terminal symbols. I'll clean out the cans using a heat gun to remove the guts, and some steel wire brushes, acetone, paper towels, and Q-Tips to clean the cans.
The donor bases are about 1/8 inch taller than the originals. Not a problem on this chassis.
Next thing to do is make up some sleeves from 1 inch PVC pipe I got at Home Depot. I forgot the exact size but maybe it's 1 1/2 inch pipe. It is the thin walled stuff. The first thing I do is true up the end using my disc sander and 90 degree guide. When truing it up, I rotate the pipe about 1/2 to 3/4 turns.
I then mark the trued up end with an arrow. This end will be glued down against the base.
I then use my 1 inch wide ruler to make a mark 1 inch up from the trued end. I go all around the pipe.
I then cut off the pipe on the line just made. I then clean up the cut end with the disc sander. I then repeat the whole process for the other sleeve starting with truing up one end.
Once I have the sleeves cut out I then de-burr them using my hobby knife and #11 blade, and some 80 grit sandpaper.
I then use 15 minute epoxy and apply the epoxy on the trued up end being careful not to get any epoxy on the outside of the sleeve. Then the sleeve is inserted down onto the base. I then clean off any and all epoxy that has gotten onto the outside of the sleeve especially down near the base. Any epoxy here will prevent a good seam when the can is put into place.
