Why are you using that set with those original paper capacitors in it?? Tube is adjusted wrong. Front of tube should fill mask.
Watch out on their AGC circuits. The wires are rubber. HV , high current in it. It gets the pulse from the flyback. They made many changes on that circuit. I have that model set. Can you send me a schematic on how that circuit is wired, along with sinc circuit on yours? Mine's a mess... Thanks.
"Tubes are those little glass things that light up orange unless there is a short.. Then they light up all pretty colors..." Please join my forum. http://www.tuberadioforum.com/ |
All the wires in mine were plastic and fine (except the ones that got mouse chewed). AGC works fine on mine too. I'll try to take some pictures of the schematic for you later.
