Old 12-08-2017, 09:18 PM
Gotcha. Thank you for posting the data, it's very interesting. Like you said there's quite a margin considering their rated life expectancy. It would be interesting to see how much warmer they run once the chassis is back in the cabinet, although a bit more difficult to aim the heat seeking light beam. What we need is a bunch of those remote temp sensors like folks are using on their telemetry equipped RC planes these days.
Old 12-09-2017, 08:29 AM
Yeah we used thermocouples taped in places all over avionics packages at work. Then we had a computer log each one every second or so IIRC. Very detailed and very eye opening as to where the heat goes. Of course we would need to come up with a custom can that would allow the thermocouple wire to exit the re-stuffed E-Cap. We could gather a ton of data and come up with a 15 page report. But then would we really do anything different than what we are doing today?
Old 12-09-2017, 12:17 PM
Honestly I so seldom watch my few restored TV's that component lifespan has never been a concern. Seems that most of us end up with a few favorite watchers, but for the most part there's not enough hours in the day once the collection grows past a dozen or so.
Old 12-09-2017, 08:53 PM
I decided to start work on the cabinet today. I removed the bezel and started to clean it up. I noticed that the "brass" area around the On-Off-Volume knob was quite well worn. It even has the thin plating worn off.
When cleaning the door the plating rubbed off with very little rubbing. And I mean very little. I then took all of the "plating" off. I thought Philco was the only one that skimped on the thickness of the plating. It looks like the aluminum door is bright nickel plated? Probably needs to be that way before it was brass plated. I guess I'll have to find a plating company to plate the door and the knob pieces. As a matter of fact, the bezel brass plating is gone along the most outer edge from repeated cleaning through the decades. I'll get an estimate on getting it all re-plated bright brass. Might even take my Predicta parts along too.
Old 12-10-2017, 12:46 AM
Looks nice in nickle, more modern. I've seen a lot of those get painted too.
